"This operation has been cancelled due to restrictions in effect
on this computer."
A very common question in the Microsoft public newsgroups goes something
like this:
When clicking on a hyperlink in an e-mail, I get this
Message : "This operation has been cancelled due to restrictions in effect
on this computer. Please contact your system administrator." I get this
message every time that I attempt to use the hyperlink. I am the
administrator on this stand alone computer. How do I deactivate this feature
so that I activate hyperlinks ?
This is not an Outlook error. The most common cause is a corrupt registry key in Internet
Explorer. The registry key found at HKEY_Local_Machine\Software\Classes\htmlfile\shell\open\command
is either
damaged or corrupt.
To fix it, try resetting Web settings in Internet Explorer. If this
does not resolve the issue, you'll need to import the registry key from
another computer.
Click the Programs tab, and then click the Reset button.
Under Internet programs, verify that the correct e-mail
program is selected.
Click to select the Internet Explorer should check to see
whether it is the default browser check box.
Click Apply, and then click OK.
If you receive a message when Internet Explorer starts telling
you that IE is not currently your default browser, click Yes to make
it your default.
If you are using Vista:
Open Internet Explorer.
On the Tools menu, click Internet Options.
Click the Advanced tab, and then click the Reset button.
On the Programs tab, under Internet programs, click Set
Programs, then "Set your Default Programs", select your e-mail program
and click "Set this program as Default". Repeat for Internet
Explorer.
Click OK and close the dialogs.
Note: You need to set Internet Explorer as default and verify the
problem is fixed. If you prefer a different browser, you can set it
as default later.
Import the Registry Key
When resetting the web settings doesn't help, you'll need to
recreate the corrupt key. The easiest way to do this is by exporting
the key from another computer.
To save exporting it from another computer, right click here to download a registry key
exported from my computer. Choose Save target as
and change the file extension from txt to reg
and double click on it to run it.
Windows XP and Vista allow you to control program defaults through
Control Panel. If the above methods fail, use
this method to set the
default browser.
In Windows XP, go to Add and Remove Programs, Set Program Access
and Defaults.
In Vista, access the
Default Programs applet from the Start menu or Control panel. Click
on the "Set program access and computer defaults" (last option) then
expand Custom. In "Choose a default web browser", check on the
"Internet Explorer" option and click the OK button
Other Causes
There are several other causes of this error. In most cases, they do
not affect hyperlinks in Outlook. If you found this page searching
for the error message, check out the following pages. Note that if
you receive this error on a computer at work, you should contact
your administrator, they may want access to applications restricted for
security reasons.
