You may receive the following error in Outlook: ---------------------------
Failed to open message store.
Microsoft Office Outlook Offline Folders
[269287937] : The file C:\Documents and
Settings\username\Local
Settings\Application Data\Microsoft\Outlook\outlook.ost
is in use and could not be accessed. Close
any application that is using this file, and
then try again. (Error: 0)
If you have a SharePoint calendar linked to Outlook, remove it to end the
error. |
